hershebmx Posted September 27, 2016 Share Posted September 27, 2016 The truth, I have not seen that. I'll check tonight. Thanks Pernacabeluda, I'll tell you the results. Quote Link to comment Share on other sites More sharing options...
FZSX Posted September 28, 2016 Share Posted September 28, 2016 ERROR Booting Usb Booting usb shows- The version of Mac OS not supported on this platform reason: mac f227bec8 How do I patch bootable usb to boot Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 28, 2016 Author Share Posted September 28, 2016 Change SMBIOS by one supported in Sierra. Also your CPU must have SSE4 instructions. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
hershebmx Posted September 28, 2016 Share Posted September 28, 2016 Hello pernacabeluda, I could make the installation of OS X thanks to your advice, change definition of SMBIOS and I could install. Now the problem is that I can only boot with USB memory and I always have to start with nv_disable = 1 so I do not have graphics acceleration. Something curious happens, I do not know which bootloader to install, install clover and surprise !, when I restart and mount the EFI partition with clover configurator, there is no EFI partition. When I try to boot from the OS X partition a prohibited symbol appears. How I can solve these problems ?. Correction, my graphics is NVIDIA GeForce GT 610. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted September 28, 2016 Share Posted September 28, 2016 hello u go solved all that problems with reading .. a lot.. about what are u trying to do .. in ur old hardware .. good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 28, 2016 Author Share Posted September 28, 2016 Others are having problem with this video card, follow this topic, no solution for now http://www.insanelymac.com/forum/topic/315351-problems-with-graphics-cards-on-the-macos-sierra/ EFI partition only exists if you use GPT. About the prohibited symbol, boot in verbose mode to find the cause. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
naeemnur Posted September 28, 2016 Share Posted September 28, 2016 Hi, great work with the installer it boots up fine, but how can i get past this screen? My System: Alienware Alpha Core i3 / 4 + 4 Gb Ram / Nvidia 860m Quote Alienware Alpha | Core i3 | Nvidia 860m | 8Gb | Samsung 850 EVO 250gb HDD | macOS 10.12 Link to comment Share on other sites More sharing options...
artur-pt Posted September 28, 2016 Share Posted September 28, 2016 hello try to use OsxAptioFix2Drv-64.efi in clover drivers64UEFI folder good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
hershebmx Posted September 28, 2016 Share Posted September 28, 2016 About the prohibited symbol, reads as follows: The version of Mac OS not supported on This platform reason: mac f227bec8 About Nividia graphic, I've read that many people have same problem, I have to wait for some solution. About GPT partition, my disk is formatted as GPT, should create the EFI partition, but when I load the partition with clover configurator finds there, but when I want to open the config.plist, ask reload the EFI partition. In other OS X versions, I had never been that. Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 28, 2016 Author Share Posted September 28, 2016 Hi,great work with the installer it boots up fine, but how can i get past this screen? If you can't replace OsxAptioFixDrv-64.efi as Artur suggested, try legacy boot (without "UEFI" before USB stick name, or disable UEFI boot in BIOS). About the prohibited symbol, reads as follows: The version of Mac OS not supported on This platform reason: mac f227bec8 Change SMBIOS by a supported one, like you did for installing. No idea about EFI problem, should be OS independent. Did you check "install in ESP" in Clover installation? Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
hershebmx Posted September 28, 2016 Share Posted September 28, 2016 Yes, I check install in ESP in clover installation. Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 29, 2016 Author Share Posted September 29, 2016 Maybe it's a Clover Configurator problem. Can you see config.plist in Finder? You can try this http://www.insanelymac.com/forum/files/file/602-clover-flying-editor/ Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
naeemnur Posted September 29, 2016 Share Posted September 29, 2016 If you can't replace OsxAptioFixDrv-64.efi as Artur suggested, try legacy boot (without "UEFI" before USB stick name, or disable UEFI boot in BIOS). i replaced it with OsxAptioFix2Drv-64.efi still got the same error, then i tried booting it up with legacy mode, didnt get any error except +++++++++ and it restarts... Quote Alienware Alpha | Core i3 | Nvidia 860m | 8Gb | Samsung 850 EVO 250gb HDD | macOS 10.12 Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 29, 2016 Author Share Posted September 29, 2016 If your CPU is Haswell enable Kernel PM Patch http://Olarila.com/forum/viewtopic.php?f=36&t=5006 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
naeemnur Posted September 29, 2016 Share Posted September 29, 2016 yes my cpu is haswell, i added the kernel patch parameter in "EFI\CLOVER\config.plist" according to that post but it still restarts.... <key>KernelAndKextPatches</key> <dict> <key>KernelCpu</key> <true/> </dict> Quote Alienware Alpha | Core i3 | Nvidia 860m | 8Gb | Samsung 850 EVO 250gb HDD | macOS 10.12 Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 29, 2016 Author Share Posted September 29, 2016 It's KernelPm not KernelCpu https://clover-wiki.zetam.org/Configuration/KernelAndKextPatches#kernelandkextpatches_kernelpm You can enable it in the options menu. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
kobiandy Posted September 29, 2016 Share Posted September 29, 2016 Wonderful installer yet again created by the spectacular devs here. One issue that seems to trouble me is this : specs are i3 2100 h61m-vs 8gig ram and 9800 gt. Upon installation in which I use nv_disable=1 to achieve I simply can't find a way to make my vga function in fullhd qe/ci. Is the 9800gt relegated in new macOS or I'm I not doing something right. Quote Link to comment Share on other sites More sharing options...
naeemnur Posted September 29, 2016 Share Posted September 29, 2016 oops let me try this, hang on Quote Alienware Alpha | Core i3 | Nvidia 860m | 8Gb | Samsung 850 EVO 250gb HDD | macOS 10.12 Link to comment Share on other sites More sharing options...
naeemnur Posted September 29, 2016 Share Posted September 29, 2016 It's KernelPm not KernelCpuhttps://clover-wiki.zetam.org/Configuration/KernelAndKextPatches#kernelandkextpatches_kernelpm You can enable it in the options menu. still same, restarting... Quote Alienware Alpha | Core i3 | Nvidia 860m | 8Gb | Samsung 850 EVO 250gb HDD | macOS 10.12 Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 29, 2016 Author Share Posted September 29, 2016 Check if your BIOS has Execute Disable Bit (NX bit, XD bit) and enable it. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
naeemnur Posted September 29, 2016 Share Posted September 29, 2016 Check if your BIOS has Execute Disable Bit (NX bit, XD bit) and enable it. I enabled Nx bit and it worked!!! now i'm going to install it and see what happens next... Quote Alienware Alpha | Core i3 | Nvidia 860m | 8Gb | Samsung 850 EVO 250gb HDD | macOS 10.12 Link to comment Share on other sites More sharing options...
pernacabeluda Posted September 29, 2016 Author Share Posted September 29, 2016 Wonderful installer yet again created by the spectacular devs here. One issue that seems to trouble me is this : specs are i3 2100 h61m-vs 8gig ram and 9800 gt. Upon installation in which I use nv_disable=1 to achieve I simply can't find a way to make my vga function in fullhd qe/ci. Is the 9800gt relegated in new macOS or I'm I not doing something right. Try another SMBIOS or edit /System/Library/Extensions/AppleGraphicsControl.kext/Contents/PlugIns/AppleGraphicsDevicePolicy.kext/Contents/Info.plist and add your Board-ID under ConfigMap with "none" config. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
hershebmx Posted September 30, 2016 Share Posted September 30, 2016 Hi Pernacabeluda. I have finally managed the installation of OS X, no problems with the EFI partition, running audio (Realtek 887), internet working. What remains pending, (I'll wait for a solution), it is the activation of the QE / CI graphics card. For today, just boot with nv_disable = 1. Thanks to your advice. Quote Link to comment Share on other sites More sharing options...
naeemnur Posted September 30, 2016 Share Posted September 30, 2016 i successfully installed it, got everything working except wifi. can you help me find the kext?? Intel® Dual Band Wireless-AC 3160 + Bluetooth 4.0 (bluetooth is working) Quote Alienware Alpha | Core i3 | Nvidia 860m | 8Gb | Samsung 850 EVO 250gb HDD | macOS 10.12 Link to comment Share on other sites More sharing options...
kobiandy Posted September 30, 2016 Share Posted September 30, 2016 Try another SMBIOS or edit /System/Library/Extensions/AppleGraphicsControl.kext/Contents/PlugIns/AppleGraphicsDevicePolicy.kext/Contents/Info.plist and add your Board-ID under ConfigMap with "none" config. Did that and still have a kp at NVDASTARTUP.kext Quote Link to comment Share on other sites More sharing options...
