artur-pt Posted November 13, 2014 Share Posted November 13, 2014 hello what patch for graphics is that ? good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
emanur9 Posted November 13, 2014 Author Share Posted November 13, 2014 Intel Graphics Patch for Mixed Configuration Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 14, 2014 Share Posted November 14, 2014 hello really don't know what that is .. like i tell u before .. i think ur graphics maybe don't work.. u don't have hd 4000 , hd 3000 or hd 2500 .. what i know that are the ones supported in mac os x .. hd 2500 some work others no.. good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
emanur9 Posted November 14, 2014 Author Share Posted November 14, 2014 But all the kexts in the folder system / library / extension must be removed and installed those in my PC? Quote Link to comment Share on other sites More sharing options...
emanur9 Posted November 14, 2014 Author Share Posted November 14, 2014 I'm trying to solve. I do not understand why I start with flag -x load properly Intel HD Graphics 2500 with VRAM of 1024. Starting without -x do not detect graphics card (says no kext installed and no installed model) How do I successfully start without -x? Quote Link to comment Share on other sites More sharing options...
emanur9 Posted November 15, 2014 Author Share Posted November 15, 2014 Please help me... Quote Link to comment Share on other sites More sharing options...
emanur9 Posted November 17, 2014 Author Share Posted November 17, 2014 but why do not you answer? I need help. I just want to understand why the system boots perfectly with -x and instead lose the resolution and VRAM on the graphics card. Thanks Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 17, 2014 Share Posted November 17, 2014 hello i post several links to u read .. by ur talk u don't read none .. we are here to help.. not to do ur job.. and again ur graphics aren't supported .. u boot with -x .. and u don't have graphics .. none of the graphics kext are loaded .. u have VESA mode.. no acceleration good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
emanur9 Posted November 17, 2014 Author Share Posted November 17, 2014 Hello thanks for the reply. But if the graphics card is not supported because with -x to boot properly? There is a way to save the startup configuration with -x? Or there is a way to allocate more VRAM after normal startup? I really can not understand how it can work with -x and without it? Is there a way to use the full functionality hackintosh with -x? Quote Link to comment Share on other sites More sharing options...
