Jeordanis Posted November 6, 2014 Share Posted November 6, 2014 I dont use any special config or boot flag. I just boot to the usb without any modification to the installer, and press 1 to enter to chameleon. After that i try all your advices. Quote Link to comment Share on other sites More sharing options...
Jeordanis Posted November 6, 2014 Share Posted November 6, 2014 Instaled clover and now im getting: System uptime in nanoseconds. Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 6, 2014 Share Posted November 6, 2014 hello u are injecting some old kext .. and the new ones are present in cache.. good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
Jeordanis Posted November 7, 2014 Share Posted November 7, 2014 Hi How can i solve that? Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted November 7, 2014 Author Share Posted November 7, 2014 Looks like you are using tonycrap tools, you should ask for help in his forum http://www.tonycrapx86.com/attachments/yosemite-desktop-support/112148d1415284253-ga-z97x-ud5h-clover-img_0371.jpg Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Jeordanis Posted November 7, 2014 Share Posted November 7, 2014 Looks like you are using tonycrap tools, you should ask for help in his forum http://www.tonycrapx86.com/attachments/yosemite-desktop-support/112148d1415284253-ga-z97x-ud5h-clover-img_0371.jpg  Hi Im using the Olarila usb build. I use the picture of tonycraps because this user have the same problem. Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted November 7, 2014 Author Share Posted November 7, 2014 Post a picture of your own screen. If you used Olarila image and official Clover installer, it can't be exactly like that one. If the installer boots, most likely you didn't configure Clover correctly. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Bruxo Posted March 10, 2015 Share Posted March 10, 2015 Hello everyone !!! I'm Yosemite sitema installed on HD seamlessly with Bootloader Clover on the EFI partition But will problems when turning off the machine The sitema off normally until the HD hear it off but the cooler cabinet and the CPU fan still working !!! I'm not using DSDT or SSDT, all settings are contained in Config.plist of Clover, activated the FixShutdown option and even then I did not succeed. Quote Bootloader - Clover Placa mãe - GA-G31M-S2L Processador - Pentium E5200 - DDR2 800MHZ 2X2 4GB Placa de video - SFX-RADEON-HD5670 - 1GB AppleHDA ALC662 Framebuffer - Uakari - injeção por Cover config HDMI, DP, DVI Yosemite 10.10.2 Link to comment Share on other sites More sharing options...
pernacabeluda Posted March 10, 2015 Author Share Posted March 10, 2015 FixShutdown works for Asus, not for Gigabyte Adds If(arg=5){} to method _PTS. This trick may repair shutdown problems for some systems (ASUS). http://clover-wiki.zetam.org/Configuration/ACPI#DSDT-/-Fixes You may try other Clover fixes or apply Gigabyte shutdown patch in DSDT http://clover-wiki.zetam.org/Configuration/ACPI#DSDT-/-SuspendOverride http://clover-wiki.zetam.org/Configuration/ACPI#HaltEnabler http://Olarila.com/forum/viewtopic.php?f=7&t=44 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Bruxo Posted March 10, 2015 Share Posted March 10, 2015 Thank pernacabeluda !!! Yes I use Gigabyte card as my signature DSDT be necessary in Clover or Config.plist already do all the fix? config.plist.zip Quote Bootloader - Clover Placa mãe - GA-G31M-S2L Processador - Pentium E5200 - DDR2 800MHZ 2X2 4GB Placa de video - SFX-RADEON-HD5670 - 1GB AppleHDA ALC662 Framebuffer - Uakari - injeção por Cover config HDMI, DP, DVI Yosemite 10.10.2 Link to comment Share on other sites More sharing options...
pernacabeluda Posted March 10, 2015 Author Share Posted March 10, 2015 You need to test. If SuspendOverride and/or HaltEnabler in config.plist do not work, try the DSDT patch. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Bruxo Posted March 11, 2015 Share Posted March 11, 2015 Thank you for your attention pernacabeluda I used SuspendOverride and / or HaltEnabler in Config.plist but have had no effect !!! I decided to use a copilada DSDT and removed all fix in config.plist of Clover and now deslina hardware perfectly !!! Thanks for the explanations DSDT.aml.zip Quote Bootloader - Clover Placa mãe - GA-G31M-S2L Processador - Pentium E5200 - DDR2 800MHZ 2X2 4GB Placa de video - SFX-RADEON-HD5670 - 1GB AppleHDA ALC662 Framebuffer - Uakari - injeção por Cover config HDMI, DP, DVI Yosemite 10.10.2 Link to comment Share on other sites More sharing options...
