pernacabeluda Posted October 24, 2014 Author Share Posted October 24, 2014 It would be useful for the next version if you find out which one of them is causing problem. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
musadiqmanas Posted October 24, 2014 Share Posted October 24, 2014 Dear @pernacabeluda, I forgot the file manager/software we used to delete files/folders from RAW image. Can u plz tell me about that? To use in Windows... Thanks. Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted October 24, 2014 Author Share Posted October 24, 2014 It's called TransMac. There's a link with instructions in the first post http://Olarila.com/forum/viewtopic.php?f=31&t=3836 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
musadiqmanas Posted October 24, 2014 Share Posted October 24, 2014 It's called TransMac. There's a link with instructions in the first post http://Olarila.com/forum/viewtopic.php?f=31&t=3836 Thanks for kind reply and sorry for stupid question.. I get it now..will try to minimize the annoying questions during my quest to install OS X 10.10 on my HP-1000 Notebook.. Regards! Quote Link to comment Share on other sites More sharing options...
abrfilho Posted October 24, 2014 Share Posted October 24, 2014 Olá, baixei o torrent desta imagem, gravei num pen-drive utilizando o Image Writer, dei boot por UEFI, abriu o Clover, selecionei o Boot Install OS X porém a tela ficou preta, apaguei as kext de vídeo e o cache, tentei novamente e a tela ficou preta no mesmo ponto, o que poderia ser? Eu tenho um ASUS K45VM Processador Core i7 3610QM 8GB Memória RAM Placa de Vídeo GeForce GT630M etc etc... Quote Link to comment Share on other sites More sharing options...
musadiqmanas Posted October 25, 2014 Share Posted October 25, 2014 Dear @pernacabeluda, Following the given instructions, I made bootable USB without any alteration and booted. It failed. Then I deleted kernel cache and video kexts as per given instructions and booted again. It again failed and said "..Error loading kernel cache" (image attached). I tried again by selecting option of "boot without caches", "boot without injected kexts and caches" and "boot in single user verbose mode" but all failed and showed the same screen (image attached). Plz tell me what should I do now? Regards! Quote Link to comment Share on other sites More sharing options...
artur-pt Posted October 25, 2014 Share Posted October 25, 2014 hello try to boot single user mode follow on screen instructions to mount the volume then kextcache -prelinked-kernel good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
musadiqmanas Posted October 26, 2014 Share Posted October 26, 2014 hello try to boot single user mode follow on screen instructions to mount the volume then kextcache -prelinked-kernel good hack I thought "single user mode" should be there in boot options but I don't see it there (image attached). It only shows "single user verbose mode" which I've already tried to no avail as I mentioned in my last post. If "single user mode" is something different and I have to do something other than what I'm doing, plz let me know. Regards! Quote Link to comment Share on other sites More sharing options...
artur-pt Posted October 26, 2014 Share Posted October 26, 2014 hello yes is that follow the instructions good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
pernacabeluda Posted October 26, 2014 Author Share Posted October 26, 2014 Try using legacy boot instead of UEFI. If Clover legacy also doesn't work, press 1 to use Chameleon, it will boot without caches. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
fbifido Posted October 27, 2014 Share Posted October 27, 2014 Hi, Just trying your installer. wait i have to tell you, I tried to get everything that will be needed to install&run yosemite. but no one would help until i install 10.10, which makes no sense. I wanted to get all the kexts that my motherboard needed, & to have my DSDT fixed. anyway in tried to install 10.10, and i am not sure what is the problem. here is a video of my so call testing: part1: "> part2: "> btw: my spec is now: msi H61M-P31/w8 (ms-7788) mother board intel Core i3-3250 Ivy-Bridge-D 3.50GHz cpu (3rd-Gen CPU with Intel HD 2500) 8GB ram, 500GB harddrive Sata Now looking into ozmosis for my board: http://www.insanelymac.com/forum/topic/301407-guide-insert-ozmosis-into-uefi-bios/#entry2075373 from this info my board is using iMac 13,2 which mean my SMC version is 2.11F14. I got this info from http://www.insanelymac.com/forum/topic/269558-fakesmc-y-plugins/ I also notice this info from the same page: - AVX verstion work only Sandy Bridge/Ivy Bridge Attached File FakeSMC_r615.zip 8.13MB http://www.insanelymac.com/forum/index.php?app=core&module=attach§ion=attach&attach_id=111925 I am also not sure which smc-compatible: to use for iMac 13,2. I currently don't have any OS X install, and would like to get all the relevant info needed to mod or repair my dsdt file. most modders are asking for IOJones files, which include .iojones & .acpi type info. Can you help me. Thanks. Quote MSI H61M-P31/W8 (MS-7788), Intel® Core i3-3250 CPU @ 3.50GHz (Ivy Bridge-DT), Intel HD 2500, everything on-board. System info: http://i62.tinypic.com/fbb21t.png Link to comment Share on other sites More sharing options...
fbifido Posted October 28, 2014 Share Posted October 28, 2014 Updated my BIOS with the ozmosis mod. still not sure if it is working (the ozmosis bootloader). anyway it can't boot your yosemite usb, so i boot with clover off the usb and ran a few utility to get dsdt files and system info. please see attach. note: i am booting from your OS X Yosemite installer USB, which is using MacBookPro6,2, and my bios is using iMac13,2. Please find attach: https://mega.co.nz/#F!QxJwCDpA!LQN038wBwiLnBodse2p6Wg Quote MSI H61M-P31/W8 (MS-7788), Intel® Core i3-3250 CPU @ 3.50GHz (Ivy Bridge-DT), Intel HD 2500, everything on-board. System info: http://i62.tinypic.com/fbb21t.png Link to comment Share on other sites More sharing options...
pernacabeluda Posted October 28, 2014 Author Share Posted October 28, 2014 HD 2500 is not supported in OS X, you may try to inject ig-platform-id=0x01660003 as suggested here http://www.insanelymac.com/forum/topic/287668-guide-intel-hd2500-full-resolution-and-qeci-1083/ You can edit Clover config.plist for this http://clover-wiki.zetam.org/Configuration/Graphics#ig-platform-id Most likely you will have to remove graphics kexts and boot without framebuffer, boot single user (from space bar menu) fsck -fy mount -uw / mkdir /kext_backup cd /System/Library/Extensions mv AppleIntelHD* AppleIntelFramebuffer* /kext_backup kextcache -prelinked-kernel reboot Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
abrfilho Posted October 30, 2014 Share Posted October 30, 2014 Olá pernacabeluda, estava tendo problemas com o Clover em EFI, a tela ficava preta, no legacy é a mesma coisa, então dei boot com o Chameleon, ele ficou numa mensagem assim: "Still waiting for root device", dei boot pelo Chameleon utilizando USBBusFix=Yes mas deu na mesma, o que devo fazer? Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted October 30, 2014 Author Share Posted October 30, 2014 Tenta com -gux_defer_usb2 -gux_no_idle Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
abrfilho Posted October 31, 2014 Share Posted October 31, 2014 pernacabeluda, muito obrigado pela sua ajuda, consegui realizar minha instalação, só tive problema com a kext da nvidia. Após instalado, estava sem som (instalei o VoodooHDA mas fica um leve chiado no fundo), o touch não funciona (instalei aquele VoodooPS2 mas nada aconteceu), as USBs não funcionam (funcionou com aquele comando que você me passou anteriormente) e estou tendo problemas com minha Intel HD 4000, ele parece que não detecta toda a memória de vídeo e o sistema fica meio lento e apresentando alguns problemas gráficos. A bateria também não aparece aqui, teria alguma coisa a ver com o Gerenciamento de Energia *ponto de interrogação* (acabei de descobrir que não consigo digitar coisas que precisam de apertar o Alt Gr no Windows) Edit: Como eu trocaria a resolução da tela *ponto de interrogação* O iMessage não está funcionando aqui. Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted October 31, 2014 Author Share Posted October 31, 2014 Tudo isso você encontra no fórum, aqui não é o lugar para questionar, use o tópico correspondente para cada assunto. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
abrfilho Posted October 31, 2014 Share Posted October 31, 2014 Ok, obrigado Quote Link to comment Share on other sites More sharing options...
cool_recep Posted November 18, 2014 Share Posted November 18, 2014 10.10.1 would be good. Thanks Quote Link to comment Share on other sites More sharing options...
pernacabeluda Posted November 20, 2014 Author Share Posted November 20, 2014 10.10.1 would be good. Thanks One of these Kexts gave me IIBluetooth error. After rmoving them, I was able to reach the installer screen. It would be useful for the next version if you find out which one of them is causing problem. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
cool_recep Posted November 20, 2014 Share Posted November 20, 2014 It is probably GenericUSB XHCI but I will make sure today. Quote Link to comment Share on other sites More sharing options...
cool_recep Posted November 21, 2014 Share Posted November 21, 2014 100% confirmation! If there is GenericUSBXHCI.kext, there is no way to boot! Even with -gux_defer_usb2 -gux_no_idle -gux_nosleep! You are stuck at No interval found for 8000000 Delete GenericUSBXHCI.kext and you are good to go. I have tried all combiantion including Inject USB, USB ownership... No... GenericUSBXHCI.kext just fucks up the entire setup. I have even tried with the one from sourgeforge with no luck. Also another update: Please make Kernel PM Patch default! And optional: add nv_disable=1 as most of the users have Intel + nVidia laptops. Quote Link to comment Share on other sites More sharing options...
cool_recep Posted November 23, 2014 Share Posted November 23, 2014 And also, please change the Clover Theme. This one is my suggestion: http://www.hackintoshosx.com/files/file/4104-yosemite-login-cloverefi-theme/ Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 23, 2014 Share Posted November 23, 2014 hello what u are asking is just to do a installer personalized for u .. no way.. remember many users don't use laptops .. clover have several themes in the installer .. that 1 is not.. the generic will see what problems may have... what we want is to have a generic installer .. we can post that info in common problems of the installer good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
cool_recep Posted November 23, 2014 Share Posted November 23, 2014 hello what u are asking is just to do a installer personalized for u .. no way.. remember many users don't use laptops .. clover have several themes in the installer .. that 1 is not.. the generic will see what problems may have... what we want is to have a generic installer .. we can post that info in common problems of the installer good hack For some parts yes, for some no. GenericUSBXHCI.kext is causing problem for everyone. Needs to be removed. Kernel PM Patch is also required for the most of the users as a lot of people use newer systems. nv_disable=1 is optional, I agree. Clover Theme also is optional but the current Theme is the worst theme ever for clover. Quote Link to comment Share on other sites More sharing options...
