oroooat Posted November 28, 2022 Share Posted November 28, 2022 I recently purchased new DDR5 32G RAM 5600 MHz (16Gb x2), which needs the F21 BIOS to operate. However, my current mobo is Z690 Gaming X (16Gbx1 5200 Mhz) with F8 BIOS have no issue with when boot hackintosh. (I assume all GA Z690 may have the same bios settings) I did flashed the bios to F21 and did the same bios setting with F8. Now I cannot boot hackintosh. stuck at [EB|#LOG:EXITBS:START] Basically my config are below Above 4G Decoding → Enabled Re-Size BAR Support → Enabled VT-d → Enabled XHCI Hand-off → Enabled Hyper Threading Technology → Enabled TSM 2.0 (Trusted Computing)→ Disabled CFG-Lock → Disabled Fast Boot → Disabled Windows 10 Features → Windows 10 CSM Support → Disabled I'm not certain not sure. Do I need a extra configuration? since I noticed 'Improve the linkage between Resizable and 4G above'  Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted November 28, 2022 Administrators Share Posted November 28, 2022 BIOS IN FULL DEFAULT SETTINGS just set xmp Quote Support Olarila Vanilla Hackintosh by making a donation HERE About Premium Users you can check HERE Problems with Paypal HERE Link to comment Share on other sites More sharing options...
oroooat Posted November 29, 2022 Author Share Posted November 29, 2022 15 hours ago, MaLd0n said: BIOS IN FULL DEFAULT SETTINGS just set xmp Here my bios setting Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted November 29, 2022 Administrators Share Posted November 29, 2022 use default settings just set ur xmp 1 Quote Support Olarila Vanilla Hackintosh by making a donation HERE About Premium Users you can check HERE Problems with Paypal HERE Link to comment Share on other sites More sharing options...
oroooat Posted November 30, 2022 Author Share Posted November 30, 2022 6 hours ago, MaLd0n said: use default settings just set ur xmp Already use default setting (Bios F21 version), enable X.M.P and attached config.plist for your reference config.rar Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted November 30, 2022 Administrators Share Posted November 30, 2022 https://www.olarila.com/topic/25111-hackintosh-efi-folders-for-all-chipsets-with-opencore-mod/ Quote Support Olarila Vanilla Hackintosh by making a donation HERE About Premium Users you can check HERE Problems with Paypal HERE Link to comment Share on other sites More sharing options...
oroooat Posted December 1, 2022 Author Share Posted December 1, 2022 Thank you for the solution 😄  Quote Link to comment Share on other sites More sharing options...
Huynh Hoà ng Văn Posted December 2, 2022 Share Posted December 2, 2022 Hey man I'm having the same issue (can't roll back to f8 because i'm using 13700kf) Does it resolve your issue yet? Quote Link to comment Share on other sites More sharing options...
Rhysrhys Posted December 5, 2022 Share Posted December 5, 2022 On 12/2/2022 at 4:12 PM, Huynh Hoà ng Văn said: Hey man I'm having the same issue (can't roll back to f8 because i'm using 13700kf) Does it resolve your issue yet? I have the same issue, for now I use the basic SSDT-OLARILA700 to boot up. When I get time I'll do another system dump and see if MaLd0n can help. Quote Link to comment Share on other sites More sharing options...
