WooAf Posted November 22, 2013 Share Posted November 22, 2013 My sound is not working at all, can someone help me to get it working ? Quote Link to comment Share on other sites More sharing options...
artur-pt Posted November 22, 2013 Share Posted November 22, 2013 hello have u try voodoohda ? http://Olarila.com/forum/viewtopic.php?f=28&t=454 good hack Quote PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files Link to comment Share on other sites More sharing options...
WooAf Posted November 22, 2013 Author Share Posted November 22, 2013 hello have u try voodoohda ? http://Olarila.com/forum/viewtopic.php?f=28&t=454 good hack Yes I have tried it I have tried AppleHDA, Voodoohda, Realtek from multishit.. idk what to do Quote Link to comment Share on other sites More sharing options...
Mirone Posted November 22, 2013 Share Posted November 22, 2013 saying only "My sound is not working" no help at all. which audio codec you have? send me a copy of your DSDT ioreg.ioreg + + codec dump. so I can help you. Quote Link to comment Share on other sites More sharing options...
WooAf Posted November 22, 2013 Author Share Posted November 22, 2013 I tried with VoodooHDA it say No VoodooHDA Devies Detected http://Olarila.com/forum/download/file.php?id=5057 Quote Link to comment Share on other sites More sharing options...
PimentelX86 Posted November 22, 2013 Share Posted November 22, 2013 Hello Try VoodooHDA newest version: http://www.projectosx.com/forum/index.php?showtopic=355 2.8.4 is great, work almost everything natively. Use Kext Wizard Obs: If you want use VoodooHDA, you'll need remove AppleHDA or install AppleHDADisabler. Update cache is best way to make anyone kext work. Quote CPU: Intel i7 2600 | Mobo: IPMH61R1 | Memória: 8Gb| Áudio: VT1705| Gráfica: GeForce GT 610 | HD: 500GB, 80GB | SO: Windows 7/OS X Mavericks 10.9 Não Damos Suporte as ferramentas de tonycrap We don't give support tonycrap's tools Link to comment Share on other sites More sharing options...
