Hackintosh macOS Ventura Beta 3 Solution - Clover or OpenCore
All credits to acidanthera team, Mr Download-Fritz, Slice, btwise and N.D.K
What we need?
with OpenCore
1- Last OpenCore Bootloader
OpenCore-0.8.3-RELEASE.zip
OpenCore-Mod-0.8.3-RELEASE.zip
2- Last Lilu kext
Lilu-1.6.2-RELEASE.zip
3- Reset Nvram (Use entry in boot picker)
with Clover
1- Last Clover version
Clover Ventura B3.zip
2- Last Lilu kext
3- Reset Nvram (F11 key in boot screen)
  • Thanks 1
20 minutes ago, Parpiyev Baxromjon said:
Hello everyone! I did it according to your instructions, but it doesn't work for me, it shuts down while updating
Hi, the same thing happens to me. downloads the update and when trying to install it keeps restarting...
the error it gives is what is in the attached image, I think it is related to the USB... Any ideas how to overcome this?
best regards
Screenshot_2022-07-07-19-12-12-20_99c04817c0de5652397fc8b56c3b3817.jpg.zip
Download update again
12 minutes ago, joaopaulomartins said:
Hi
19 minutes ago, Parpiyev Baxromjon said:
I still don't update it after downloading it, it drops it half way through
What we need?
with OpenCore
2- Last Lilu kext
with Clover
2- Last Lilu kext
Thanks Mald0n
Enjoy!
Enjoy!
u need to use 11gb update
just replace files
i am on Beta 2 and works grate but when i try to update to beta 3 machine reboots...
Core I7 Haswell
AMD RX 580 8GB
DDR 3 32GB 1600MHz Ram
Asus Z97A
Please Help!!
Thank You so much.
Core I7 Haswell
AMD RX 580 8GB
Asus Z97A
Please Help!!
Thank You so much.
i was able to fix it...
reset NVRAM went back in to my HD add Last Lilu kext from above and redownload beta 3 and reboot.
My Build # 3: GA-Z370XP-SLI | I7-8700K | Sapphire Nitro+ RX 580 8GB | Mojave (10.14.2)
My Build # 2: GA-Z97X-UD7 TH | i7-4790K | Sapphire Radeon RX Vega 64 8GN HBM2 | Mojave (10.14.2)
My Build # 1: GA-Z77X-UD5H | i7-3770K | MSI Radeon RX 580 8G V1 8GB | Catalina (10.15.4)
Thank you very much!
Your infos makes me back in the game! Beta 4 works oob now with last OC 0.8.3. + last lilu.kext.
I updated my EFI via OCAuxiliaryTools (yesterday) and my bootloop (IOUSBHub20....) is gone! :)
Thanks MaLd0n!
(i7 4790k, Asrock Z97X Killer, RX 580 8 GB)
Edited by Honza
Enjoy!
