Some Options
-This app
Webdriver All Versions.app.zip
or
-WebDriver and Cuda bellow working with no modification required. 10.13.6 (build 17G14042)
NVIDIA_macOS_10.13.6.zip
or
Step 1. Disconnect.
Step 2. Boot into Safe Mode. Everything will be extremely laggy, be patient.  (-x in clover will boot safe mode, safe mode is essential step..will not work otherwise)
Step 3. Launch Terminal and enter the command ‘sudo nano /etc/hosts’, once prompted provide the password. (You can also use something like little snitch to block instead of changing hosts...in step 3 &4)
Step 4. Append the following lines to the file’s contents:
127.0.0.1 ocsp.apple.com
127.0.0.1 ocsp2.apple.com
127.0.0.1 ocsp.digicert.com
Save changes and exit.
Step 5. Run the following batch of Terminal commands:
crlrefresh rp
sudo rm -f /var/db/crls/*cache?.db
sudo date -u 020200002020
sudo reboot
-GasMask is simple hosts file manager for macOS. It allows editing of host files and switching between them. Link HERE
by eierftucht on MacRumors site
  • Like 2
