8 hours ago, MaLd0n said:
1- add -igfxvesa on bootargs
2- use hackintool to check video patch
Thank you!
How can I add bootargs on opencore?
I dont see any terminal options.
And what is the command line I should imput?
Thank you so much : )
yes
4 hours ago, MaLd0n said:
yes
Thank you so much I got to get in. I have installed hackintool.
Please correct me, I have gone into patch. It already selected
-USE Intel HDMI
-Spoof Video Device ID
Should I add something else?
After that I click generate, and it returns me some lines of code.
I assume that code goes into the plist right? If so could you tell me in which section? If not could you tell me where to paste it?
Thank you so so much
I have question @MaLd0n or anyone. how do i know which kexts to use for my hardware. Like internet its broadcom AsRock OC formula z77. anything else i need how to know which one. can help. Thanks. I will be donating to soon. I love this project.
Hey
with Olarila efi folder u just need remove extra Lan kexts
6 hours ago, MaLd0n said:
Hey
which one do i keep for internet and remove?
Edited by linuxwow
u need check what lan card ur mobo have
Hi impossible for me....Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz   2.59 GHz.  when I try to start the installation, it starts an infinite bootloop....I really don't know what to do.
gets stuck on this part, very soon when it starts...."In memory panic Stackshot Succeeded...Bytes Traced 12240....Attempting System restart.
it resets and starts the loop again over and over again.
use this folder https://tinyurl.com/n24hpz5x
if need disable video patch and add -igfxvesa for easy installation
Sorry but I don't know in which folder I have to dump the EFI files. I do it with Transmac? . I'm pretty lost, excuse me! on the other hand, the -igfxvesa command. In what section do I have to enter it or in what terminal? since at the beginning of oralila it only shows me 3 logos. the one to start the installation and 2 more some nvram reset and one more. but I am very limited from the boot. Also if I press 0 , it only puts me in the first box with the installation logger.
could someone give me a solution? i'm totally lost
Some Basic Information
@MaLd0n How do i install clover with legacy boot for MONTEREY Olarila
boot0ss in ESP
