likkai
Bluetooth not working even after loaded IntelBluetoothInjector
My wifi card is AC 9560 160 MHz, the wifi works but only the bluetooh doesn't. I asked the collaborator at GitHub and he told me to use the BlueToolFixup.kext to fix the problem. But the only problem is I couldnt find it, seems like it requires compilation using xcode but I can't run xcode. Can anyone help me get the files here?
Link to the GitHub: https://github.com/acidanthera/BrcmPatchRAM
Link to the issue:
https://github.com/OpenIntelWireless/IntelBluetoothFirmware/issues/308
Link to comment
Share on other sites
BlueToolFixup.kext i think only support broadcom cards
-Donations-
Link to comment
5 hours ago, rilav41255 said:
Thanks for the link. No wonder I couldn't find it, it was released 24 hrs ago. Bluetooth works now but unfortunately both handoff and airdrop doesn't work.
Link to comment
Likai, boa tarde!!
Instalei as kexts BlueToolFixup.kext e Intelbluetoohfirmawe.kext mas o bluetooh não ativa. Alguma dica? Grato.
MSI Z690 Gold Ace
PROC Intel i12900k
MEMO Corsair Dominator - 5600mhz - 32GB
VGA Asus TUF Gaming - AMD 5700XT
HD's M.2 - 04 (Samsung 970, HP, XPG) de 01T - 02 SSDs Samsung Evo 850 (01 TB) -
Link to comment
Prezados, boa noite!!
Após a atualização do Monterey Beta 10 o bluetooth deixou de funcionar.
É reconhecido, mas não conecta.
Alguma dica?
Grato.
MSI Z690 Gold Ace
PROC Intel i12900k
Link to comment
On 10/16/2021 at 10:04 AM, Gervasoni said:
Pessoal, bom dia!
A solução encontrada é substituir a kext BlueFixBoot.kext para a versão 2.6.1 .
Aqui funcionou.
Desculpa estar revivendo a thread, mas qual versao do IntelBluetoothFirmware.kext voce esta usando?
Tentei diversas combinacoes mas tudo que o relatorio de sistema me mostrava era uma placa broadcom e com o MAC nulo.
A placa que tem nesse lenovo e uma Intel AX201, infelizmente soldada na placa.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
