artur-pt Posted September 13, 2012 Posted September 13, 2012 hi man boot with -v from the usb or dvd and u see what kext are loaded. or use in terminal kextstat and see or in about my mac full report extensions good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
linarense Posted September 14, 2012 Author Posted September 14, 2012 I have solved the USB problems using this kext: https://www.dropbox.com/s/0f3zb6pgfd6dmpl/IOUSBFamily.kext.zip Finally I have my hackintosh fully working!!!!! Dual boot win 7 + ML. Thanks to all who have helped me
linarense Posted September 17, 2012 Author Posted September 17, 2012 I have a question... It´s normal that the battery in Windows 7 goes dead 3 hours and in Mountain Lion only 1 hour and a half????
mdkstn Posted October 29, 2012 Posted October 29, 2012 Hello guys, finally I managed to install ML on my laptop. I have working almost all: bual boot win7 + ML, trackpad and keyboard, ethernet, webcam, sound, intel HD4000... Now I only have two problems: - Wifi: I´ve tested a lot of kext without success -> Atheros AR9485 Wireless Network Adapter - USB: When I connect something to the USB ports (2.0 and 3.0) system hangs I have to reboot the computer. Any help to finish my installation??? Thanks!!! Can you share the kext which is used for Atheros AR9485 Wireless Network adapter as well as the trackpad? I have the same network adapter with you and it can not work at all. My email is: mdkstn.vnuit@gmail.com Thanks in advance.
linarense Posted October 29, 2012 Author Posted October 29, 2012 Sorry, I can´t use my wifi adaptor, no kext for this chip. I connect to net through ethernet.
