Jackall01 1 Posted October 22, 2020 Share Posted October 22, 2020 On 10/20/2020 at 11:27 AM, Syonagar said: Hi... Anyone got any compiled binary for opencore 0.6.3? I know there is no official release yet. Thanks &Â Regards. https://github.com/williambj1/OpenCore-Factory/releases 1 Link to post Share on other sites
vivandi 1 Posted October 23, 2020 Share Posted October 23, 2020 Can you guys help me with Acer Aspire 3 A315-54k-37x3 Trackpad is not working Please Quick https://easyupload.io/uomr9t Here is run me file Link to post Share on other sites
Administrators MaLd0n 1,001,041 Posted October 23, 2020 Author Administrators Share Posted October 23, 2020 24 minutes ago, vivandi said: Can you guys help me with Acer Aspire 3 A315-54k-37x3 Trackpad is not working use it, reboot, extract new sendme config.plist.zip Link to post Share on other sites
vivandi 1 Posted October 23, 2020 Share Posted October 23, 2020 (edited) i Will try OK Â Edit: macOS BigSur Beta 9 will not boot its stuck on loading screen Edited October 23, 2020 by vivandi Link to post Share on other sites
AlanOliveira 0 Posted November 5, 2020 Share Posted November 5, 2020 Hi people! I'm trying to install BETA 10 but it presents msg "device is write-protected" And it doesn't arrive at the installation. How to solve? Processor: Core i5-4690 Haswell  Link to post Share on other sites
vivandi 1 Posted November 6, 2020 Share Posted November 6, 2020 (edited) On 11/5/2020 at 1:57 AM, AlanOliveira said: Hi people! I'm trying to install BETA 10 but it presents msg "device is write-protected" And it doesn't arrive at the installation. How to solve? Processor: Core i5-4690 Haswell  Bro Simone has posted Problem solved by adding -s to boot-arg and beta 10 successfully installed Edited November 6, 2020 by vivandi Link to post Share on other sites
pepemix40 0 Posted November 6, 2020 Share Posted November 6, 2020 (edited) I am trying to install the big sur rc from usb and it is giving me panics, someone who can give me a cable, THANKS. WhatsApp Image 2020-11-06 at 13.05.33.jpeg.zip Edited November 6, 2020 by pepemix40 Link to post Share on other sites
Administrators MaLd0n 1,001,041 Posted November 7, 2020 Author Administrators Share Posted November 7, 2020 3 hours ago, pepemix40 said: Â check quirks Link to post Share on other sites
AlanOliveira 0 Posted November 12, 2020 Share Posted November 12, 2020 On 11/6/2020 at 1:53 PM, vivandi said: Bro Simone has posted Problem solved by adding -s to boot-arg and beta 10 successfully installed I tried this flag to no avail. same message: device the write locked. Link to post Share on other sites
suren munoo 3 Posted December 23, 2020 Share Posted December 23, 2020 Anyone has the OC 0.6.4 remade EFI Folder  Link to post Share on other sites
Administrators MaLd0n 1,001,041 Posted December 23, 2020 Author Administrators Share Posted December 23, 2020 1 hour ago, suren munoo said: Anyone has the OC 0.6.4 remade EFI Folder  https://tinyurl.com/y3fm5ub2 1 Link to post Share on other sites
suren munoo 3 Posted December 23, 2020 Share Posted December 23, 2020 1 hour ago, MaLd0n said: https://tinyurl.com/y3fm5ub2 Thanks Mate Link to post Share on other sites
