macOS Big Sur 11 beta 10 (20A5395g)
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Olarila BigSur Beta 10 https://www.olarila.com/topic/6278-new-vanilla-olarila-images/
-Olarila BigSur Beta 10 https://www.olarila.com/topic/6278-new-vanilla-olarila-images/ ย  -Hackintosh Users. Check some useful infos bellow for Beta 10 Update ย  -ma
Updated. Thanksย ๐Ÿค— HEVC work again.
22 hours ago, Rezarg said:
During installing big sur beta 10
i got this error and stuckย ::ย
Disk4 : device is write lockedย
how can i fix this?
Before that I installย big sur beta 9 successfullyย
Problem solved by adding -s to boot-arg and beta 10 successfully installedย
Link to post
Share on other sites
1 hour ago, tarantababu2002 said:
on "about about this mac" screen, it's only CPU 4 Ghzย
You will never see your cpu detailed description of your cpu there.ย
May you choose the correct smbios and connect to internet. Then the it will update the description.
Link to post
ย
Displays properly with opencore versions earlier than 0.62, but this version only writes processor speed.
ย
Searched for a long time, looked at all remedies but couldn't find a way to fix it.
Link to post
ย
ย
-macOS Big Sur 11 beta 10 (20A5395g)
ย
Update to beta 10 using this method but encountered a problem when booting my hack. I now shows apple logo on the boot screen then login then verbose. How to fix it?
Boot image
Link to post
Problem solvedย ๐Ÿ‘ย  OC creates a number in the "processor type" tab in PlatformInfo.ย When I deleted that number and restarted, it came back like a CPU name๐Ÿ‘Œ
Edited by tarantababu2002
Wrong word
Link to post
strange
update bootloder and kexts, reset nvram and try again
11 hours ago, David Ramos said:
Is fully instalable?
yes. only full vanilla here. From apple and full dsdt patches
Link to post
On 10/18/2020 at 5:06 AM, Jรผri Pranstibel said:
I am installing to external SSD, stuck with disk 6 device is write locked. How did -s (i guess it is the flag for single user mode?) help? Can you be more specific?
Justย setย csr-active-configย toย FF0F0000
And use -s in boot-arg then reboot and reset NVRAM
ย
Link to post
10 hours ago, MaLd0n said:
strange
Tried but same problem. I even tried to boot it using my past config but same result
Link to post
Did anyone getย https://github.com/OpenIntelWireless/itlwmย running on beta 10 ? I just received my Intel AX 200 wifi card which (I later found out) requires this driver to run, however this driver requires Misc -> Security -> Security Boot Model to be set to Default.
I can only boot my system with the Security Boot Model to Disabled, I have also tried toย Force IO80211Family to load as per documentationย https://openintelwireless.github.io/itlwm/Installation.html#itlwmย . The system boots and the wifi card works for a few seconds then stops working.ย
Other than that everything seems to be working great.ย
ย
Thanks in advance
My Setup is :ย
CPU:ย  ย Intel i5-10400 6Core
Motherboard:ย ASROCK Z490 Pro 4
GPU: Radeon RX 580 8Gb
Edited by Jackall01
Link to post
:cap-Please Disable Your ADBlocker and Support Our Forum-:cap
