zfigz Posted September 16, 2011 Share Posted September 16, 2011 Which trackpad is it (ALPS, Synaptics)? If it's Elantech you can try removing VoodooPS2Trackpad and it may work using VoodooPS2Mouse. Yeah, I think it's an Elantech. I'm doing another fresh install of OS X and I'll give it a go. Thanks for the pointers, guys. Do you have that particular kext, Cassio? I only see VooodooPS2Controller and VoodooPS2Trackpad in multishit. Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 16, 2011 Share Posted September 16, 2011 I use SL_PS2_Voodoo.zip from this topic http://www.insanelymac.com/forum/index.php?showtopic=175372 just removed VoodooPS2Trackpad from VoodooPS2Controller.kext/Contents/PlugIns Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
zfigz Posted September 16, 2011 Share Posted September 16, 2011 I use SL_PS2_Voodoo.zip from this topic http://www.insanelymac.com/forum/index.php?showtopic=175372 just removed VoodooPS2Trackpad from VoodooPS2Controller.kext/Contents/PlugIns Woah?! I got it to work with this http://chameleon.osx86.hu/file_download/25/VoodooPS2Controller-0.98-installer.pkg No double finger scrolling, though. Any idea how I might be able to get double finger scrolling? Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 16, 2011 Share Posted September 16, 2011 Did you remove the trackpad plugin or is it working? Mine works with the mouse plugin (2 fingers scroll/middle click and 3 fingers right click). Use a more recent version, this 0.98 pkg is for Leopard. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
zfigz Posted September 16, 2011 Share Posted September 16, 2011 Did you remove the trackpad plugin or is it working? Mine works with the mouse plugin (2 fingers scroll/middle click and 3 fingers right click). Use a more recent version, this 0.98 pkg is for Leopard. Ok, I did it using your directions and the same thing happened. I can use the trackpad, I just don't have double finger scrolling. The trackpad prefpane in preferences says "No trackpad found" and when I click on the VoodooPS2 prefpane it says "ApplePS2SynapticsTouchPad not found" and then it opens. Then it just quits if I adjust anything. Any ideas? Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 16, 2011 Share Posted September 16, 2011 The trackpad prefpane in preferences says "No trackpad found" This is normal if using mouse plugin. when I click on the VoodooPS2 prefpane it says "ApplePS2SynapticsTouchPad not found" and then it opens. You must be using wrong version of prefPane. In my case using the mouse plugin made 2 fingers scroll work, but I had no option, all versions of trackpad kexts I tried didn't work. If yours works with trackpad plugin, try to find one that works better. Are you sure it's an Elantech? Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
zfigz Posted September 16, 2011 Share Posted September 16, 2011 This is normal if using mouse plugin. You must be using wrong version of prefPane. In my case using the mouse plugin made 2 fingers scroll work, but I had no option, all versions of trackpad kexts I tried didn't work. If yours works with trackpad plugin, try to find one that works better. Are you sure it's an Elantech? I'm guessing and found this (http://www.amazon.com/Lenovo-Ideapad-09143YU-15-6-Inch-Laptop/product-reviews/B004G608VU) review of about the same model of computer...they said it was an Elantech. Do you know where I could get another version of the perfPane? The only thing that has gotten it to work is removing that trackpad kext. Anyhoo, thanks again for your help! Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 17, 2011 Share Posted September 17, 2011 There's a prefPane in the package I use (SL_PS2_Voodoo.zip) Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
phvrctnt Posted September 17, 2011 Share Posted September 17, 2011 Can you help me patch my DTST. System is a Lenovo G470 attached is the file generated on runme. I am able to do the following. iboot > install SL > iboot > install 10.6.6 can't boot on HDD, need iboot to access system. Thanks in advance System Specs i3-2310 Intel HD 3000 Atheros Wifi AR 9285 Atheros LAN Connexant HD Audio 4GB RAM HM65 Chipset I hope the details helps... send_me.zip Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 17, 2011 Author Administrators Share Posted September 17, 2011 Can you help me patch my DTST. System is a Lenovo G470 attached is the file generated on runme. I am able to do the following. iboot > install SL > iboot > install 10.6.6 can't boot on HDD, need iboot to access system. Thanks in advance System Specs i3-2310 Intel HD 3000 Atheros Wifi AR 9285 Atheros LAN Connexant HD Audio 4GB RAM HM65 Chipset I hope the details helps... dsdt phvrctnt.zip Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
phvrctnt Posted September 17, 2011 Share Posted September 17, 2011 Thank You so much kind sir... Will update post once I've tried it. Probably in the next 30 minutes. Thank you again. [attachment=0]dsdt phvrctnt.zip[/attachment] Quote Link to comment Share on other sites More sharing options...
phvrctnt Posted September 17, 2011 Share Posted September 17, 2011 after installing the DTST and neccessary ktexts. Why am I stuck in the apple logo (no spinning wheel)? How do I work around this problem? Thanks! Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 17, 2011 Author Administrators Share Posted September 17, 2011 use a clean install you need http://www.insanelymac.com/forum/index.php?showtopic=258611 Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
phvrctnt Posted September 17, 2011 Share Posted September 17, 2011 use a clean installyou need http://www.insanelymac.com/forum/index.php?showtopic=258611 I'm actually on a clean install updated to 10.6.6 upto this point, I can only access using iboot. I have a few questions though. Do you mean, before using the patched DTST, i need to do the following in order. 1. install 10.6.8 2. install multishit 3. install speedstep? Sorry for such trivial questions. Really just learning osx86 Thanks. Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 17, 2011 Author Administrators Share Posted September 17, 2011 I'm actually on a clean install updated to 10.6.6 upto this point, I can only access using iboot. I have a few questions though. Do you mean, before using the patched DTST, i need to do the following in order. 1. install 10.6.8 2. install multishit 3. install speedstep? Sorry for such trivial questions. Really just learning osx86 Thanks. same procedure http://Olarila.com/forum/viewtopic.php?f=16&t=136 Use NULL in S/L/E NullCPUPowerManagement 32 64.kext.zip after use speedstep and remove NULL Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
aelsharawi Posted September 17, 2011 Share Posted September 17, 2011 hello ,thx for this great tool I need your help regarding my DSDT. my build is: Z68A-D3-B3 core i52500K ATI HD5670 [DVI,CRT,HDMI] Please ,I need a proper DSDT that enables built in Audio,and enables Native Ati frameBuffer my current setting using DSDT from tonycrap and I enabled audio using the non DSDT audio Also the video was enabled using the chimera boot loader Graphic enabler=Yes without it I couldn't Get framebuffer to work but I cant get 1080p from HDMI,the Graphic enabler=no loads 1080p but no framebuffer. Thx in advance It seems I'm not following the role here ! what shall I do to get my request done ? thx Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 17, 2011 Share Posted September 17, 2011 It seems I'm not following the role here ! what shall I do to get my request done ? thx The DSDT patch for your mobo is available here http://Olarila.com/forum/viewtopic.php?f=22&t=385 Your video problem has nothing to do with DSDT. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
aelsharawi Posted September 17, 2011 Share Posted September 17, 2011 The DSDT patch for your mobo is available here http://Olarila.com/forum/viewtopic.php?f=22&t=385 Your video problem has nothing to do with DSDT. thc a lot for quick reply is this is the audio code for sound card ? so It will be supported OOB ? into device name_adr 0x001B0000 set_label begin HDEF end; into_all all code_regex AZAL replaceall_matched begin HDEF end; into method l so what I understand is to do these steps: I have the tonycrap DSDT so I will (download the txt patch file): - reboot without a DSDT replacement (remove dsdt.aml from / or /Extra and restart), you may need NullCPUPowerManagement to avoid kernel panic - start Mac OS using a boot CD (why do i need to go again into mac ?????/) - use Windows or Linux version of DSDT Editor - extract DSDT using Windows or Linux and open it in Mac OS, instead of using "extract DSDT" will it differ from tonycrap DSDT,will it solve my wake from sleep Issue, can I insert a code for ati frame buffer into it ? thx Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 18, 2011 Share Posted September 18, 2011 is this is the audio code for sound card ? so It will be supported OOB ? No, read about "HDEF patch" in that topic. why do i need to go again into mac ????? It says "choose one", it means you don't need to do all of them, just one. will it differ from tonycrap DSDT,will it solve my wake from sleep Issue, You will have to test it. can I insert a code for ati frame buffer into it ? Which code? You can insert anything, but if it will work or not depends on what you insert. Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
vonhellsing Posted September 19, 2011 Share Posted September 19, 2011 Help me Please! I dont know how or types of patches apply in DSDT i have one P8h67m-evo, with core i3 1155 Processor DualCore Intel Core i3-2100, 3200 MHz (31 x 103) motherboard Asus P8H67-M Evo (1 PCI, 1 PCI-E x1, 2 PCI-E x16, 4 DDR3 DIMM, Audio, Video, Gigabit LAN, IEEE-1394) Chipset mobo Intel Cougar Point H67, Intel Sandy Bridge Video Card: Nvidia 9400 GT 512 Audio: Realtek ALC892 @ Intel Cougar Point PCH - High Definition Audio Controller [b-3] Please if is possible patch for me, i´ll be really HAPPY cheers! von-p8h67m-evo.rar Report.rar Quote Link to comment Share on other sites More sharing options...
Cassio Posted September 19, 2011 Share Posted September 19, 2011 The patch for your mobo is available here http://Olarila.com/forum/viewtopic.php?f=22&t=385 Quote -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
sinoseven Posted September 19, 2011 Share Posted September 19, 2011 Hi ! This is my DSDT. I install Lion and system work's fine but i want to remove nullcpupowermanagement.kext. When i remove i got KP. Please help me to resolve this problem.. What dsdt modification i must do ? Samsung NP350U2A Mobile DualCore Intel Core i5, 2000 MHz (20 x 100), x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3 Intel Cougar Point HM65, Intel Sandy Bridge Intel HD 3000 dsdt.zip Quote Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted September 19, 2011 Author Administrators Share Posted September 19, 2011 Hi ! This is my DSDT. I install Lion and system work's fine but i want to remove nullcpupowermanagement.kext. When i remove i got KP. Please help me to resolve this problem.. What dsdt modification i must do ? Samsung NP350U2A Mobile DualCore Intel Core i5, 2000 MHz (20 x 100), x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3 Intel Cougar Point HM65, Intel Sandy Bridge Intel HD 3000 dsdt.sinoseven.zip Quote -Donations- PayPal HERE - Stripe HERE - Ko-Fi HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 - BNB 0x10D1d656eCa00bD521f9b4A43B83098B8142e115 - USDT BSC BEP20 0xb57cfdfa371fad1981910f0e8332409ab99f74d9 - USDT TRC20 TUR6Z9AVS4AYzqPnULoHrfFvppRbhXmNbZ - KASPA kaspa:qpxzufgfj8p6r0krg58yzvs0009h2mwqgvcawa0xc2pth7sgzpv56j4f6dtvk - PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Sign up for a Bybit account and claim exclusive rewards HERE New ways to earn money with Linkvertise HERE Link to comment Share on other sites More sharing options...
sinoseven Posted September 19, 2011 Share Posted September 19, 2011 [attachment=0]dsdt.sinoseven.zip[/attachment] Not working for me still KP Quote Link to comment Share on other sites More sharing options...
vonhellsing Posted September 19, 2011 Share Posted September 19, 2011 The patch for your mobo is available here http://Olarila.com/forum/viewtopic.php?f=22&t=385 Hi cassio. I try when i try compile get many errors, and my machinne turn off with MacOs Advisor ! Any idea ? I belive thats some about thermal control from processor! cheers! angelini Quote Link to comment Share on other sites More sharing options...
