Hackintosh macOS Big Sur and Monterey with Clover
On 10/5/2020 at 6:44 PM, MaLd0n said:
inside ACPI folder?
thank you very much , now work ( Duel MacOs & Windows 10 )
Edited by Kankon
Motherboard Asus TUF Z390-PLUS GAMING (WI-FI) CPU 3.6 GHz 8-Core Intel Core i9, Ram 32 GB 3000 MHz DDR4, Graphics : RADEON RX 580 8GB GOORS (XFX) OS:MacOS Monterey 12.0 Beta (21A5284e) SERIE 30, 40 (COOFFELAKE / COMETLAKE)
Link to comment
Share on other sites
Hello
Special thanks. to sir MaLd0n for having altruism and making available his. work congratulations
On my pc works perfectly after some modification with clover configurator. (I don't know what to use but tried.) could have the sound on HDMI and recognition of my screen everything works
many thanks
The thing I would like to do but so far not successful. it is in place of the labels of the selected disk
here: put a different text
eg: macOS BS
Windows 10
macOS Catalina
macOS Mojave
Boot macOS from macOS BS = macOS BS
and also hidden from internal drives
big thanks sir and sincere congratulations
Regards
PS : sorry.  try put. pic .png. not possible.  and sorry. english no natural language!!!!
https://www.casimages.com/i/20100908535725664017074121.png.html
https://www.casimages.com/i/20100908535625664017074120.png.html
https://www.casimages.com/i/20100908535725664017074122.png.html
Edited by jm26200
Mac mini macOS Monterey 12.7.5 (21H1211)
Carte mère : GA-Z590 UD AC, CPU : Intel BOX I5-11400 LGA : 1200, RAM 32 Go DDR4, Intel Rocket Lake-S GT1 - Graphiques AMD Radeon RX 6600 8 Go - OSmacOS Sonoma 14.5 [Open Core 1.0.0 ] (23F5059e) & Windows 11 Professionnel Insider Preview (canal Canary) 24H2 26200.5001
Link to comment
On 10/8/2020 at 12:45 PM, tasco11 said:
Does your Big Sur beta 9 has 'Clocks' tab inside Syst Pref>Dates and times? Mine is gone. So there left 2 tab only.
u mean this ?
Link to comment
1 hour ago, m.grandinetti said:
hello, can you update your version with clover 5124
i'll check it
  • Thanks 1
-Donations-
Link to comment
10 minutes ago, Andrius Castillo said:
hello, how to fix the EFI folder to used for skylake laptop
I'm using Lenovo Y700-15ISK, i7-6700HQ, 256GB SSD, 1TB HDD, 16GB DDR4, please
The quickest way is find the efi folder which is run machine as same as your configuration (hardware specified).
The other one, you have to choose and select also configure by yourself, from driver, kext, acpi table and so on.
Link to comment
if not available, how can I generate my own EFI folder to be used with clover? I cannot find a working procedure :(
Link to comment
-Donations-
Link to comment
I have a I3-2120 (Sandy Bridge CPU) and my motherboard supports uefi with it
What prebuilt efi should i use because i tried to make a efi for myself but it wont work, would always end up giving up.
Can someone help me
i am on Niresh's catalina and it works for me but can i update it to big sur?
Link to comment
it's time to update hehehe
-Donations-
Link to comment
Can someone help me
Niresh system is modified. Better you download olarila, since it was a vanilla image.
Link to comment
4 hours ago, Tristan Listanco said:
When will Skylake+ laptops will have a EFI folder for clover 5123 or 5124?
need wait release for updates
-Donations-
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
